Solid Wood Machining
Rougherhead
3/30/18
Luke Smith Member
Does anyone have a picture of the type of setup required to make a "rougherhead" texture? I've attached a couple pictures. I've seen this look on lots of pine shiplap. We manufacture rustic mouldings and I need to be able to put a rougherhead texture on some southern yellow and ponderosa pine mouldings.
I've looked all over the internet but can find little information on how to achieve this look.
View higher quality, full size image (1003 X 604)
3/31/18       #2: Rougherhead ...
Wire Brush Machine.
3/31/18       #3: Rougherhead ...
Russ
Website: http://www.mr-moulding-knives.com
Hello Luke I hope your doing well, I would agree this was probably done with a wire brush. We have combing knives that would give you a similar look, but not exactly the same as you show, you could also offset the knives to get a custom look. Page 17 in the link below, toward the bottom of the page.They are just straight knives with the corrugation going both horizontally for the cutter head and vertical for the rustic look. Simple to maintain, you sharpen them like any other straight knife set.
Catalog
4/2/18       #4: Rougherhead ...
cwwoodworking
Good Luck Luke in what you are doing, but a similar product can now be bought at HD and Menards.
I make Picture frames out of the Menards material. I can buy a 1x6x8 pine for about $6. The Menards material actually looks better. It has less scraping pattern.
4/3/18       #5: Rougherhead ...
Luke Smith Member
Thank you all for the responses so far.
The rougherhead surface on some of the pine at Home Depot / Menards is basically what I'm trying to match, only on some different shapes of moulding.
I've tried some different wire brush setups but can't find anything coarse enough to give this pattern - Does anyone have a photo of the setup? Or know of any wire brush companies who might be able to build one?
4/4/18       #6: Rougherhead ...
cwwoodworking
Hey Luke, one other thing to remember is that different species of wood look different with these types of brushes.
Menards uses some type of fir most of the time, but occasionally they use southern yellow pine.
In the raw state, you can clearly see a difference. I paint these and then sand it off to give it an "old" look. When done, there is little difference.
I prefer the softer fir because it looks more random, more f*&cked up.
Maybe a flap sander with a head that has cut flaps on it to match your profile?
Take the sandpaper, trace the profile on it, and custom cut it on a bandsaw?
6/6/18       #7: Rougherhead ...
David Waldmann Member
Website: vermonthardwoods.com
Have you looked at the Discotelsisal products?
Available from Tech Mark in AR.
http://www.tech-mark.com/discotelsisal/stainless-steel-wire-brush-wheels >http://www.tech-mark.com/discotelsisal/tynex-wire-brush-wheels
One other issue/question is, what machine do you have available to run this on? You probably need a fair amount of pressure and power to achieve the look you want, especially on harder woods.
6/16/18       #8: Rougherhead ...
dave
Your photo looks like the finish we get from a set of "rougherhead knives" on our moulder. We take an old set of knives and notch them about every 1/16 or so with a 1/16" cutoff wheel on the bench grinder, producing a series of small points. Sliding a couple of knives side to side will vary the pattern. I think rougherheading started as a way to size export lumber to avoid the duty on "dressed" material.
