Solid Wood Machining
Widebelt Sander Air Tracking Help Needed
2/25/19
Website: http://www.superiorcabinetryandmillwork.com
Hi,
I have an old 1984 model A.Costa brand widebelt sander. The sander has the air tracking system on it. On one side, there is an air line that constantly blows air towards a spoon shaped electric switch. When the belt tracks towards the spoon shaped switch, the air stream gets "broken" and it causes the spoon shaped switch to flip forward. When it does that, it deenergizes the coil on the pneumatic solenoid valve which then sends air to one side of the air cylinder that pushes the top roller forward and that causes the belt to track away from the spoon switch. I've got that part figured out. But, I can't figure out what causes the belt at some point to track back towards the spoon switch. The spoon switch is only on one side of the sander. I have noticed that there is a pressure switch that is located on the side of the machine that is opposite from the spoon switch. I have wondered if that has anything to do with it. I've been having trouble with the tracking at times and I'm trying to figure the problem out. Tracking back towards the spoon switch is what messes up sometimes. Any help is appreciated. Thank you.
3/6/19       #2: Widebelt Sander Air Tracking Help N ...
BH Davis  Member
It may be natural positioning of the roller. On my old Timesaver of the same vintage there was an electric eye instead of your air stream. Result was the same though. When the electric eye was interrupted it activated the solenoid that pushed the drum tilt in the other direction.
There was also a hand screw that you would turn to bring the main drum tilt to a neutral position while the machine was running. If you don't have a similar adjustment screw then I have to assume that you are just working against the standard angle position of the drum as built.
By the way that is a well explained question. Nicely done.
3/7/19       #3: Widebelt Sander Air Tracking Help N ...
Kenny
Picking up where you left off in your explanation-as the belt moves away from the jet of air, the air jet is then able to re-engage the spoon on the switch, which reverses the cycle and tracks the belt back towards the air jet.
3/7/19       #4: Widebelt Sander Air Tracking Help N ...
Kenny
On my timesaver there is a threaded knob that is used to roughly dial in the tracking. If this is adjusted the wrong way, the belt just runs away from the air jet (in my case electronic eye) and runs off the machine.
Adjustment the other way controls how fast the belt oscillates. I have mine set to cycle about once per second. Once in a while I will get a belt that tracks weird and I have to slightly adjust this.
