Solid Wood Machining
Splitting on a moulder
4/30/19
Niel72 Member
Website: http://www.nrburnett.co.uk
I am just looking for some advice on using a splitting saw on a moulder.
Is there anyway of stopping the finished product from bending or is it just the nature of the wood. I generally split 6 inch into 3 inch with a splitting saw on the 2nd bottom head.
I've been asked the question over and over again but have no real answer apart from wood is a natural product.
Is there something i am doing wrong?
5/19/19       #2: Splitting on a moulder ...
In general, yes, it's wood and it'll do that.
The drying process is the culprit. If you are taking kiln dried wood, buying it and throwing it through the molder to be split as soon as you get it, it'll likely bend like that. Some will, some won't.
When I cut wood for a project I cut the width wider than necessary and then I re-joint and cut again to get a straight pc off the saw. And it works most of the time, but it's wood and it'll do what it wants to do when you relieve the stresses by cutting it.
If you store the wood in a proper area the wood will become more stable over time. The same wood you are cutting fresh will bend, but after months of sitting around will now cut straighter for the most part. Never a guarantee, just usually.
