Solid Wood Machining
Top and Bottom Planing several strips together
5/2/19
Latif TOKUR Member
Website: http://www.tokur.com
Hi All,
Do you know any accurate way to top and bottom plane several lumber strips together at the same time using moulder? There is no need for side planing; top and bottom only.
5/2/19       #2: Top and Bottom Planing several stri ...
Dustin orth
I double face plane all the time on my moulder. I have spiral insert heads on 1st bottom and top. Then the last bottom is a titan quicklock with straight knives. I can run about 50 to 60 lineal feet per minute and get a good finish. As far as running more than one board at a time, do you need more quantity than 50 feet a minute? Then you need to move into a double sided planer that can handle multiple boards at the same time with the same feed speed.
5/5/19       #3: Top and Bottom Planing several stri ...
BH Davis  Member
You would need segmented infeed rollers. I don't know if those exist for moulders. They can be found on some larger planers, but I don't know what is out there for double sided planers.
