Solid Wood Machining
RE: Grit of wood using a Planer
7/9/19
Tommy
Can a piece of wood, whether it be red oak or gum, be tested for smoothness coming thru a 2-foot planer
In other words, how do we know what finished grit would be the finish from a planer? Is there a testing tool?
7/10/19       #2: RE: Grit of wood using a Planer ...
Fred
Hi Tommy,
I guess you can count knife marks per inch?
7/10/19       #3: RE: Grit of wood using a Planer ...
Grit is from a sanding machine.
KCPI (knife cuts per inch) is from a planer.
The two do not compare directly.
You are probably thinking of what grit you should start sanding with. That depends on what kind of sanding equipment you have.
7/11/19       #4: RE: Grit of wood using a Planer ...
bobjh
Are we possibly talking about an abrasive planer?
7/12/19       #5: RE: Grit of wood using a Planer ...
Ryan
Planer finish is calculated in Knife Marks Per Inch. Have a look at the link below from Mirror Reflections. This explains it all.
Mirror Reflections - Knife Marks Per Inch
