Solid Wood Machining
RE: Used Wide Belt Sander
7/1/19
Tommy
We need to sand 1/2" to 3/8" wood that is 12 to 18 inches wide, and 12 feet long.
What inexpensive sanding machine is recommended without going to a time saver?
Ideally we would like to have 2 or 3 grits.
Is there any good used wood machinery company that we could purchase this from?
What brand sander would you suggest?
7/1/19       #2: RE: Used Wide Belt Sander ...
It would be a huge help to know how many linear feet a day you want to run. If it's substantial, the labor costs on using a cheap drum sander would be quickly outweighed by the labor savings with a wide belt machine. Cheap does not always save you money!
7/3/19       #3: RE: Used Wide Belt Sander ...
You should mention what geographical part of the world you are working in, budget, if any, limitations (power, dust collection, etc.).
A used equipment dealer in Ohio may not want to go to Utah.
There are links here on Woodweb for reputable dealers. I have used Exfactory, and IRS - Industrial Recovery Services with no problems. Looking thru their sites, you can see the range of things that can do what you want, and the relative pricing.
7/24/19       #4: RE: Used Wide Belt Sander ...
Adam West  Member
If you would like you can private message me. I work for an abrasives company and I calibrate hundreds of wide belt sanders every year. I teach sanding in general. I'm familiar with all brands and I can lead you in the right direction.
