Solid Wood Machining
How do you prep the inside edges of stiles and rails before assembly?
9/4/19
Ken Member
So I'm getting into areas that I don't do on a normal basis. On a 5 piece door for instance, what do you do with the inside edge of the stiles and rails? With glue line ripping, planing, shaper, etc. I still don't feel it's ready for finish. Do you run this edge on an edge sander? My concern there is losing the machined geometry when the coped end goes together. I hate reinventing the wheel so I'd thought I'd check with the forum. Thanks.
9/5/19       #2: How do you prep the inside edges of ...
Eddie
I offset my shaper fence and take about 1/16'' off of the stile and rail, with the right feed speed and spindle rotation, you'll get a nice and clean edge.
9/5/19       #3: How do you prep the inside edges of ...
D Brown
I lightly hand sand them get rid of any fuzz the detail won't change. Gives you an opportunity to break the inside edges also.
9/7/19       #4: How do you prep the inside edges of ...
I do the same as Eddie. Destructive cut at 1/16" and then a light standing, just a couple of strokes of 150 grit before assembly.
