Solid Wood Machining
Sliding table shapers
1/17/21
PJ
Question for you guys- Some of the shops that I have worked out of, I have used a few sliding table shapers with a tenoning attachment. Obviously the tenoning attachment is bolted to the slider and can be moved toward the cuter head and away. Many of the new sliding table shapers just have a sliding table and fence. How are you running tenon parts with this set up? I do a fair amount of angled tenons with angle blocks attached to the tenoning table with double stick tape. I couldnt do that without the tenon table. Also, the fence, do you attach a cut through block to eliminate any blow out? Im sure a picture is worth a thousand words for what Im asking.
Thanks in advance.
1/20/21       #2: Sliding table shapers ...
The removable tenon tables that the Mid European shapers had/have are similar to the table sliding type of shaper. Obviously, they are smaller. But you do have the option of mounting them close to the spindle, and adding a plywood or aluminum deck. The fence is also capable of being moved for angles other than 90 degrees
1/20/21       #3: Sliding table shapers ...
PJ
Thanks Dave. I currently use a "home made" version of that. I've never seen one available for sale. Thoughts on where to find one?
1/22/21       #4: Sliding table shapers ...
Joe Calhoon
I have the Panhans version of one of these. Martin US now sells the one made by Hoffman and I believe SCM sells theirs here. Don’t know of any other sources in the US. The Panhans one is available in Europe. Occasionally they come up used here but not very often.
I like these better than the in-table sliders. The built in side mount sliders are best for serious tenoning. The weakness of the bolt on type is handling long workpieces.
On mine a chipbreaker can be attached with screws to the cross fence.
View higher quality, full size image (1280 X 958)
