Portable sawdust pellet production
8/22
Hello!
I'm looking for a possibility to produce woodpellets from sawdust in different sawmills but I cannot find appropriate equipment for that. Maybe someone can help me?
The ideal would be a truck (with dryer, hammer mill and everything) i could move from place to place.
I would most appreciate your help!
Markus
8/22 #3: Portable sawdust pellet production ...
I am familiar with pelletpros.com but they are not quite what I am looking for, I could use more powerful and more easily operable (everything together).
12/24 #7: Portable sawdust pellet production ...
dear sir
we can supply the sawdust pellet mill.
The wood pellet mill can be powered by both diesel engine and E/motor. We adopt the new design Of direct connection of motor shaft and the main shaft that overcome the loose defect of belt connection as Long time using.
A diesel eingine is another choice to drive the machine, together with the clutch and accelerating decelerating Device to change its speed. It is still for the belt to drive the main shaft. The machine can run smoothly and with Few noises.
Advantage:
1. It can process the oil cake and other mixed waste material to granule at one time. And it is columned granule
Feed and have slippery firm.
2. During the process of producing granule, the temperature can almost reach 70_80 centigrade. It can make
Fecula into paste. The inner granule is cooked and fully penetrating, and is not easy to go moldy and
Degenerative. Then it can be stored for a long time and improve poultry dainty and assimilation function.
3. It also can shorten the period of feeding, so it can efficiently guarantee many users' productive cost.
Parameters of wood pellet mill Item No
Capacity
Power
N/G weight(kg)
Pellet diameter
Outside(cm)
Length
Width
Height
KL360A
800-900kg/h
55HP
750/800
6-8mm
220
62
126
KL360C
800-900kg/h
22kw
470/500
6-8mm
129
56
106
Buy & Sell Exchanges | Forums | Other Resources | Site Map
Buy and Sell Exchanges
Lumber Exchange
Machinery Exchange
Classified Ad Exchange
Forums
Adhesives Forum
Business and Management Forum
Cabinetmaking Forum
CAD Forum
CNC Forum
Professional Finishing Forum
Forestry Forum
Project Gallery
Commercial Kiln Drying Forum
Sawing and Drying Forum
Solid Wood Machining Forum
Veneer Forum
WOODnetWORK
Other Resources
Industry News
Video Library
Repeated Forum Abuse:
Forum Posting Form Guidelines
Your Name
Your Website
E-Mail Address
Subject
Thread Related File Uploads
