Value Added Wood Processing
Best way to sand edges for s4s lumber
12/3/08
Wade Frazier
I am creating s4s lumber from rough boards to be used in the finish work on an old house built in 1809. I have a wide belt sander to sand the surface of the boards, but I'm not finding a good way to sand the edges. Any suggestions ?
12/3/08       #2: Best way to sand edges for s4s lumb ...
Stephen Member
I would rip them to width 1/32nd to 1/16th over size, and then run a gang of them on edge through your wide belt/or a planer.
12/8/08       #3: Best way to sand edges for s4s lumb ...
Website: lrgwood.com
An edge sander with a stock feeder would work pretty well. If the boards will fit upright in your widebelt gang them like Stephen said. If the edges just need to look clean and don't need to be really square a clamp jig and a belt sander will do if all else fails.
12/8/08       #4: Best way to sand edges for s4s lumb ...
Wade Frazier
Thank you both for your help.
