Value Added Wood Processing
waterproof mdf
6/8/09
dennis lilienthal Member
simple ? where can i find a source for waterproof mdf, seen it @ a show but don't remember where to get it ???
6/8/09       #2: waterproof mdf ...
Bob
Medex is a brand of water resistant MDF. It's made by Sierra Pine. The link below should help you.
http://www.sierrapine.com/index.php?pid=23
6/8/09       #3: waterproof mdf ...
thanks verry much that's what i needed !
6/8/09       #4: waterproof mdf ...
Leo G
Website: http://lrgwood.com
Medex is water resistant. Extira is water proof. Google it.
1/27/17       #5: waterproof mdf ...
Kevin Member
Website: http://finepointcabinetry.com
Where are you located? I'm in north jersey and I get it delivered from Roberts Plywood, they're located in Deer Park NY seam to have a very large area which they distribute to. One thing to be careful with Medex is that it tends to have allot of movement when cutting up your 4x8 sheet. I suggest cutting your rips over sized then ripping one edge straight then reripping to desired widths. It sounds like a bit over kill but if you cut the sheet directly in half you'll end up with 2 bananas and you will notice when making ur cross cuts that your pieces will have trouble ending up perfectly square. Other than that the product is very good. I've let a puddle of water sit on it all day long to see how durable it is and their was barely if any swelling. Best of luck!
