Veneer
veneer newbie question
11/11/12
chris
I have a vac bag and get the concept. I have done a few very basic veneering jobs but am lacking the knowledge of how to veneer edges. For example, a cabinet with inset doors and "face frame" or dividers are veneered with the grain flowing from doors to divider to next door and so on. Do you just use paper backed and contact cement it? The reason I got a vac bag is because of the horror stories I have heard using contact. This example would most likely be for a "high end" residential cabinet or furniture.
11/19/12       #2: veneer newbie question ...
John Costin
Chris --
While there certainly are shops that would use paperbacked "veneer" and contact cement in the situation you are describing, it is not the best way to go about it. It sounds like you are really interested in learning the best methods for veneer work -- good for you!
Real veneer craftsmen would most likely use clamps and cauls to veneer the edges and frames you're talking about. Getting good continuity of grain can be quite tricky; you need to cut economically and align very carefully. It definitely takes some practice, especially if you're not experienced with gluing veneer edging on panels. But you will really be advancing yourself as a craftsman if you seek to learn how to do this, and you will not have to worry about getting a phone call that the edge is peeling off of your "museum-quality" piece of furniture!
Best of luck,
John Costin
Veneer Services Unlimited
vsu@gwi.net
(207)985-7221
Custom Veneered Products for the Woodworking Industry
11/19/12       #3: veneer newbie question ...
chris
Thanks for the input John. Clamps and cauls...ugh. Sounds like a challenge. clamp creep or whatever thats called again would concern me. How to keep the veneer from even slightly shifting during clamping? I have had boards shift 1/8" in 10 minutes under pressure (thats a guess).
11/19/12       #4: veneer newbie question ...
Rich
" I have had boards shift 1/8" in 10 minutes"
How accurately do you think you can lay down veneer with contact cement? All of a sudden, there is a lot of contact cement talk with veneer. Sad to see all this surface again. It's my opinion, contact cement is for high pressure laminate. That's all! For an elaborate grain matching job, you have to do a lot of planning ahead to keep the match going. You need enough material to trim to from oversize pieces. You don't have to leave the cauls and clamps on overnight, an hour would probably work if the the temp is good. Craftsmanship is about doing the job right. Easy fast work is for temporary throw away stuff. You are headed in the right direction, find a local mentor if possible. The internet is no place to find a highly skilled craftsman. It's only a place to get lots of opinions, most of them are worth what you pay for them.
11/20/12       #5: veneer newbie question ...
Chris
Point taken. I guess it is as "simple" as that. Cauls and clamps.
