Veneer
Intermediate veneer layer
11/19/12
Roger Member
Hi, my name is Roger and I am a new member of Woodweb. As I near retirement from my day job I am building a secondary source of income for my retirement years retrimming auto interiors.
A current project I have involves re-veneering a Jaguar XJS interior wood work: I have an aluminum panel with two layers of veneer one “intermediate” layer of a light colored straight grain veneer glued to the aluminum with a glue that is very hard and yellow in color. On top of that is the finish elm veneer. My question is what would make a good/best veneer to duplicate the original factory technique of one veneer over the aluminum with the finish veneer on top of that?
Thank you,
Roger
11/21/12       #2: Intermediate veneer layer ...
jason
Roger
Man, talk about a niche market! I thought selling custom furniture was hard.
I would suggest a good straight grained light wood anigre or maple. Since you are dealing with lots of curves, the anigre might bend a bit easier.
What type of adhesives are you using, and is this all hammer veneer work? How do you deal with compound curves, for example where radius'd edges meet at corners?
Seems like really challenging work, good luck to you.
Jason
11/21/12       #3: Intermediate veneer layer ...
Roger Member
Thanks Jason,
There aren’t many curves – only over the edge of a straight aluminum panel. I have some rather plain elm veneer I’m going to try as the base veneer with a PPR glue. If that hardens to my satisfaction then I’ll use a veneer glue with the finish layer of Carpathian elm over it. The techniques will be a combination of vacuum and hammer/roller. No compound curves on this one.
Roger
11/21/12       #4: Intermediate veneer layer ...
John Van Brussel
Website: http://www.veneersystems.com
I would stick to PPR as it is a thermoset adhesive that will not reactivate. White or yellow glues can resoften if heated up enough. The interior of a car can get pretty hot in the summer. Also you won't have to worry about cold creep.
11/30/12       #5: Intermediate veneer layer ...
Bob
Roger, we've had good luck with Gorilla Glue bonding veneer to aluminum car parts. Used it on some flat and some curved parts. Just need to heavily scuff the aluminum with something like 40 grit to give it some tooth.
Bob
