Door cores -- 0 --
5/3
Website: http://www.triepke.us
I have a client who is insisting on a stave core door for a almost 4'wx10' tall door instead of a scl core. I really could use some clarification on what is better stronger, etc.
What are the differences between the 2 cores?
Is there a difference with structural rigidity?
It seems to me they are both great cores.
He wants to use soss hidden hinges.
Any help would be appreciated
5/3 #3: Door cores ...
From my experience with such tall doors it is rely hard to keep them stable no mater the core. For hinges I recommend Tectus concealed hinges, they are expensive but worth the many and are 3D adjustable. We did several doors that tall and haw some problems with warping mostly related to uneven climate in the room and in the hallway.
English is not my first language so if you don't understand something I will elaborate.
Damir Dehlic
Tectus hinges
5/4 #4: Door cores ...
Website: http://www.betterbuildinghardware.com
For the reasons Damir mentions, the Tectus hinges are excellent when you are talking about large doors. The Tectus System offers hinges with capacities from 88 lbs to 660 lbs. with only two hinges installed. However, as you noted, there is often movement of the door over time and many include a 3rd hinge installed in the center of the jamb to keep things in check.
From our experience, it is recommended with doors of this width that the third hinge is installed about 11" down from the bottom of the top hinge. However, every situation, especially with larger doors, should be reviewed with us.
The ability to easily adjust the TECTUS hinges in 3-dimensions (it just takes a turn of a hex key) help to keep things neat and flush as the years roll on and the house settles. You can download the full Simonswerk TECTUS System Brochure below.
If you are looking to do a hollow core, just be aware of the minimum depth required for the mortise, when spec'ing the door leaf.
View larger image
Simonswerk_TECTUS_SystemBrochure.pdf
TECTUS Hinge System Brochure
12/5 #5: Door cores ...
Stave core is a thing of the past, and should be. I would never recommend it for any door, and the wider and longer the door the more problems you are likely to have. I'm sure it's too late to help you with this customer (looks like you posted your question months ago) but for future reference, stave core is NOT a good choice.
0 --
Buy and Sell Exchanges
Lumber Exchange
Machinery Exchange
Classified Ad Exchange
Forums
Adhesives Forum
Business and Management Forum
Cabinetmaking Forum
CAD Forum
CNC Forum
Professional Finishing Forum
Forestry Forum
Commercial Kiln Drying Forum
Sawing and Drying Forum
Solid Wood Machining Forum
Veneer Forum
WOODnetWORK
Galleries
Project Gallery
Sawmill Gallery
Shop Gallery
Shopbuilt Equipment Gallery
Other Resources
Industry News
Video Library
Repeated Forum Abuse:
Forum Posting Form Guidelines
Your Name
Your Website
E-Mail Address
Subject
Thread Related File Uploads
