Veneer
FSV + Pinch roll veneer process?
6/11/13
Eric Member
I have a job that requires veneering (wood- 10mil paper back) panels, have picked up a pinch roll. I want to use FSV adhesive. Can someone give me a rundown of the best procedure with this system? This is not production so I will be spreading the adhesive by hand. Best way to spread? When running the panel through the roll how do you keep from getting squeezed out adhesive on the roll or panel?
I also have some metal laminate panels that will require contact cement, best procedure with roll?
The substrate in both cases is MDO plywood
6/16/13       #2: FSV + Pinch roll veneer process? ...
Charles  Member
Website: http://www.northcreekwoodworks.com
It won't work. Press it.
6/17/13       #3: FSV + Pinch roll veneer process? ...
John Van Brussel
Website: http://www.veneersystems.com
This won't work because you will not get enough pressure for a long enough time to get a good bond. Also if you want to use the FSV glue do not use a J-roller or other rollers you will not get enough pressure. You will need to use a scraper or veneer hammer for best results.
6/18/13       #4: FSV + Pinch roll veneer process? ...
Leo G  Member
Website: http://www.lrgwood.com
Just a curiosity question. I recently did a paper backed veneer and used a J roller then a scraper. Got a good bond and don't foresee any issues.
What I don't understand is why is a J roller good enough for laminate but not for paper backed veneer?
Inquiring minds would like to know. :smile:
6/18/13       #5: FSV + Pinch roll veneer process? ...
Eric
Thanks for the replies.
I have been told in spite of what is said on the data sheet, FSV adhesive does not work with a pinch roll. Wilsonart does make a adhesive that is for this application that I am exploring.
8/14/13       #6: FSV + Pinch roll veneer process? ...
Kamil Antos Member
Website: http://wisewoodveneer.com
This is a bit late but it is in response to Leo's question.
J roller doesn't allow for enough psi. Paper backed wood veneer requires more pressure than laminate. As you know wood moves and plastic laminates less so if at all. The extra psi is required to help minimize the flexibility of the glue line with contact or pressure sensitive adhesives.
