Veneer
conference table questions
9/24/13
Robert Ring  Member
I have a conference table job coming up and I'd like some feedback to validate or redirect my planned approach. The job is for a table top only - the client has an existing base. Here are the specs:
Size: 96"X44" rectangular.
Substrate: 2 layers of 3/4 MDF (calibrated)
Face veneer: figured anigre (2-ply wood-on-wood Edgemate Allwood sheet product)
bottom veneer: maple (same Allwood sheet product)
Adhesive: Unibond 800 UF
Edging: 2.5"W solid cherry
I'll be using a vacuum press for laminating the MDF panels and pressing the veneer.
I plan to either biscuit or spline the cherry edging to the panel.
Any thoughts? I'm wondering if particle board would be a better substrate. Should I be concerned about the integrity / durability of the edging joint?
Also wondering if conversion varnish (ML Campbell Crystal) is the best topcoat.
I appreciate any input or suggestions regarding my approach.
Thanks,
Rob
9/24/13       #2: conference table questions ...
Robert Ring  Member
one additional question - are there any advantages to using a wood-on-wood backed veneer vs. a 10mil paper backed? I've only worked with raw veneers before so I'm leery of paper-backed, but perhaps for no good reason.
9/25/13       #3: conference table questions ...
Tom E Member
Robert,
I would think there is a big difference, have you ever heard of wood on wood de-laminating? For a top only 44”x 96” minus the edging, why not buy a layup ¾” panel if you can and save the cost of labor. This is the way I would go before I use any kind of off-the-shelf back veneer.
Having said that you work with raw veneer and you know to use ridged type glue, why not make your own top? Tom
9/25/13       #4: conference table questions ...
Another consideration when using the sheet product, it will come in sanded. That reduces the veneer thickness you get, and will give you less to work with at the joint of the wide cherry band.
9/26/13       #5: conference table questions ...
Robert Ring  Member
good points. My major issue is a tight delivery timeframe. Right now I don't have the extra time to mess around with cutting and joining raw veneer so I was trying to save the labor there. But upon further consideration I've decided to have a panel shop press the panel for me - drives up my materials cost but saves me in time and labor. They're going to hot press the veneer onto an 1 1/8" PB core. I'll edge and finish.
Rob
