Veneer
Veneer Stain Bleeding
10/8/13
Myles
Recently we have started seeing what we are calling bleeding. (Picture Attached) We have not changed any sanding or staining procedures. Our building is humidity controlled. We are seeing it on most of our wiping stains. The darker stains you can see it if you look at it from an inch away, but the light stains really show up. Does anyone know what is causing this and how to prevent it?
View higher quality, full size image (4128 X 2322)
10/8/13       #3: Veneer Stain Bleeding ...
Myles
Going to answer my own post. We cut the door width and length. The problem occoured yesterday. We still found wet stain in the gap behind the veneer panel. The why it happens is solved, now we are going to work on the solution. We are leaning towards viscosity of the stain. If anyone is reading this and would like to add anything, please feel freee.
10/8/13       #4: Veneer Stain Bleeding ...
Tom E Member
Myles,
Try a clean rag with a blast of air. The rag to catch the stain flying out of the gap, the air to move the stain and dry what is left behind.
Tom
10/8/13       #5: Veneer Stain Bleeding ...
Rich C.
Yup, compressed air and maybe not flooding the stain on so heavy near the rails and stiles.
10/9/13       #6: Veneer Stain Bleeding ...
mark
I wouldn't be so quick to change products. Perhaps, that's the right answer, but it may be something else. Is your panel fit unusually sloppy? Does your finisher have enough time to do a proper job?
Counter-intuitively perhaps, you may have better results with a less viscous stain that dries faster. The problem seems to be that the finish is drawing the still-wet stain out. At any rate, I'll agree that compressed air at the wiping stage would solve your problem, even though That is not a procedure that we follow.
10/10/13       #7: Veneer Stain Bleeding ...
Robert Member
I've seen this issue pop up now and then. The end grain of the center panel absorbs the excess stain. If this same door had been placed in a vertical position, the excess stain might have presented itself in the form of a run.
The forced air accompanied with a clean rag is about the easiest way to clean the excess stain.
The dados might be cut a bit to wide, that extra gap between the panel and the frame is an ideal area for the stain to hang out.
