Veneer
Putting Glue on Veneer in Bent Lamination
1/6/14
Howard
typically i've put glue on the substrate(wiggleboard if bent lam) and then laid down the veneer. I've seen some folks put glue on the veneer also. It's worked ok for me just to glue the substrate, but I was wondering what others are doing. thanks
1/7/14       #2: Putting Glue on Veneer in Bent Lami ...
Scott Sober  Member
Website: http://www.cymafurnituredesign.com
substrate only, avoids having the veneer cure up in an annoying manner.
1/23/14       #3: Putting Glue on Veneer in Bent Lami ...
John Van Brussel
Website: http://www.veneersystems.com
This is usually only done when using contact cement. If you are using PVA or UF glue it means you will be using double the amount of adhesive. This will create a weaker bond. In most instances with veneer and glue less is more. Also the veneer with glue on one side will curl and make it a bear to handle.
