question for veneer specialists -- 0 --
3/5
i was just wondering if over sanding or sand thru the veneer on a veneered panel will cause veneer bubbles or lifting once its been polished. We have had experiences with this but i need someone who can explain to me why. Is it because the exposed glue on the over sanded area reacts to the laquer? Hope you guys can help me with this. Thanks in advance!
3/7 #2: question for veneer specialists ...
Arlan --
What kind of glue was used on these panels? Urea or most PVA's shouldn't be affected by lacquer. Is it possible that there was a little lift already in the panel that wasn't noticed until after sanding, or that the lift actually caused the sandthrough?
John Costin
Veneer Services Unlimited
vsu@gwi.net
207-985-7221
Custom Veneered Products for the Woodworking Industry
3/7 #3: question for veneer specialists ...
Hi David,
We use UF glue to press our panels. I do think that the veneers bubbles might have been caused by something else besides the veneer being oversanded and it is possible for the veneer to have lifted before polishing and we did not notice. I had asked other persons with knowledge about veneers and adhesives and they said the same thing. Thank you for your advice.
3/11 #4: question for veneer specialists ...
Website: http://oakwoodveneer.com
Depending on your method of pressing whether using a vacuum press or a platen press - one problem using UF glues in a vacuum press is the glue going off before the bag is evacuated or you get the platen down in a mechanical press. This is a common cause for glue line issues that you don’t know are there until you begin the finish process. UF glues are touchy and you need to follow gluing standards to the letter. The advantage to PVA glues and pressing is that you have flexibility in open times and can reach pressing pressure before the glues starts to dry. Also there are several different types of PVA that you can use for more complex laminating tasks. Both glues are very solvent resistant so its unlikely the finishes are causing the bubbles and more of an actual glue line issue from the start.
3/11 #5: question for veneer specialists ...
We use a platen press to laminate our panels. Is it possible that we use too much pressure (4 kg/cm3) to laminate our veneers which causes to the glue to be spread too thinly?
3/12 #7: question for veneer specialists ...
Pressure seems low by my math.
0 --
Buy and Sell Exchanges
Lumber Exchange
Machinery Exchange
Classified Ad Exchange
Forums
Adhesives Forum
Business and Management Forum
Cabinetmaking Forum
CAD Forum
CNC Forum
Professional Finishing Forum
Forestry Forum
Commercial Kiln Drying Forum
Sawing and Drying Forum
Solid Wood Machining Forum
Veneer Forum
WOODnetWORK
Galleries
Project Gallery
Sawmill Gallery
Shop Gallery
Shopbuilt Equipment Gallery
Other Resources
Industry News
Video Library
Repeated Forum Abuse:
Forum Posting Form Guidelines
Your Name
Your Website
E-Mail Address
Subject
Thread Related File Uploads
