Veneer
Veneer over solid ash
3/27/14
Pete
I have some file drawers about 13" wide and anywhere from 14-33" long. Two rows of them with a single piece of ash veneer on the face for a continuos grain look.... question is the core. WOuld you glue up ash to get the thickness(one inch) and veneer both faces or would you use mdf and apply solid wood edging?
3/27/14       #2: Veneer over solid ash ...
Pete
To add to this.... ash is 1/16" thick for face....Would be pressed with unibond in a bag... Would you cross band b/w the face and core? if so with 1/16 thick?
3/27/14       #3: Veneer over solid ash ...
I would stay away from MDF for drawers. It has a hard time supporting itself, much less files. It also takes joinery like wet bread.
Solid Ash, with the same thickness veneer on each side will be fine. No need to cross band unless you have to restrict cross grain movement, then do the same on each side. The cross bands can be whatever thickness or even species, as long it is the same on both sides of the core.
3/27/14       #4: Veneer over solid ash ...
Pete
Thanks Dave.
Its an applied drawer front with a profile on the top edge instead of a pull... finish thickness is 1 1/8" . I glued up the core in ash and am a bit under in thickness now. I may cross band just to get my thickness back....
3/29/14       #5: Veneer over solid ash ...
Dave
The most economical route is to edgeband a veneered panel product (even if you have to stack it). For a custom veneered product, I prefer to edgeband MDF and then veneer it.
MDF is by far the best bang for the buck as far as veneering substrates go. Its flat, consistent, stable, and glues well.
Veneering over solid wood would be my last choice and I would definitely use a crossband ply.
