Veneer
Hvac vac
5/30/15
Dan cook
Has anyone ever used an hvac vacuum for vacuum veneering? I see them far sale all the time.
5/30/15       #2: Hvac vac ...
Yes, I use a 8 CFM HVAC pump with my frame press. I have run it for 7 years or so. No problems, however you should place a check valve or ball valve at the intake to the pump otherwise the bag negative pressure will draw the pump's oil up the hose. I have not but should also get around to installing a filter. I recently changed the oil and found a mess of saw dust in the lines and reservoir. Boy it runs better when clean.
