Veneer
Vac Bag Question
5/28/15
Tom
I have a vac bag set-up and the closures are a tube with a "c' type part that snaps over it. I am having a real chore putting them togethr and taking them apart. Joe woodworker recommended I wax it but it seems to have gotten worse.
Suggestions??
Thanks!
5/29/15       #2: Vac Bag Question ...
Kevin Jenness
An alternative would be two flat battens and some spring clamps.
5/30/15       #3: Vac Bag Question ...
My bag came with snap closures too hold the end folded over. You could add velcro tabs to do the same. Also the farther you put your work away from the end the easier it is to close without creases.
6/1/15       #4: Vac Bag Question ...
Tom
The batten and spring clamps worked great! Thanks!!
