Veneer
Using Crossband Backer Under Showface Veneer
12/18/15
howard Member
I would like opinions please. I've started using PVA for most flat work or gently curved, substrate good birch plywood. I do not use a crossbanding backer, just glue the substrate, put down the showface and into the vacuum. Have not had any problems with this. I was just reading something on how a crossband backer adds strength, and in the case of curved work, keeps the veneer stable. Even when I do very curved work in a bent lamination with unibond, I stil have only used the show veneer. So, would you mind helping me out on when and if a crossband backer is really necessary. Thanks Folks!
12/18/15       #2: Using Crossband Backer Under Showfa ...
Jared
It sounds like you addressed your own concern...if it's working for you, why change? I've also seen others using a perpendicular backer but have never done it myself (I use no backer, just raw veneer with PPR or epoxy). It would seem to make smaller radius curves that much harder to bend over a mold.
