Veneer
Quarter sawn grain wrap
7/17/17
Gregory Pennenga
I have a client who wants wall panels that wrap a bump out in her wall (panels will have mitered returns on two sides). She wanted the grain to flow continuously from one side to the other around each mitre. She has chosen an engineered, quarter sawn mahogany veneer. My question is since we're using a nice tight quarter sawn, does the veneer actually need to be continuous around the mitres? Will anyone be able to tell whether it's an actual "waterfall"? Of course if we were using flat sawn it would have to be one continuous flitch but is it necessary with quarter sawn?
Any advice is appreciated.
7/17/17       #3: Quarter sawn grain wrap ...
Charles Wright  Member
Website: http://www.northcreekwoodworks.com
If it's easier for you, just do it. No one will ever know, nor could anyone tell. For us we always miter/fold as it's easier.
7/17/17       #4: Quarter sawn grain wrap ...
Greg Pennenga
Thank you Charles. I should clarify, the grain is going to run horizontally. You think that no one could tell that the grain isn't actually continuous?
My alternative is to order 12' sheets of mdf laid up with a 12' veneer in order to get my continuous grain.
Thanks again,
Greg
7/17/17       #5: Quarter sawn grain wrap ...
Oh. I would not make that call without seeing the material.
Where are you located?
7/17/17       #6: Quarter sawn grain wrap ...
What kind of finish? Often the end grain will be darker when finished, so yes do a miter.
7/18/17       #7: Quarter sawn grain wrap ...
Paul Miller
You can order veneer sheets and if you need more than one, ask that they be end matched. I have done this for wall panels running up a tall wall, running vertically. For a tight grain look, order a slip match, end matched.
7/19/17       #8: Quarter sawn grain wrap ...
Greg Pennenga
Charles, I'm in Sarasota, Fl. I get most of my veneer from Certainly Wood up in NY.
Rich C., I use a spray on stain and a urethane sealer/top coat system. Will definitely mitre since this will be veneer on mdf so no endgrain to speak of.
Paul Miller, I will ask about that end match! Thank you!
Update: The cost of purchasing 12' layed up panels of mdf was TOO MUCH $. So I am going to do the layups myself which means buying a 12' bag (insert angry emoji).
7/19/17       #9: Quarter sawn grain wrap ...
Paul Miller
I get my veneer sheets from Hi Tech Veneer. They are in Southern Indiana and I ask for Roger. I believe he is very knowledgeable.
Good luck.
7/19/17       #10: Quarter sawn grain wrap ...
So you would loose the bid if you did this? Did you figure the cost of the bag into your money saving? I've figured this out over the years, that thinking I would save money by not hiring a specialist to do something because I could save money by doing it myself is a false hope. If they do it all the time, they know the pitfalls. Besides, I can be making other money while they do the layup.
