Veneer
Time in bag for epoxy glued veneer
9/30/18
Joe M Member
I have experience using the vacuum bag for smaller pieces and use a cold press glue all of the time. I also have epoxy experience with some boat projects so I have idea but...
Now I have a door project and will use West epoxy (207 hardener) to glue a sheet of veneer on a built up MDO door. I know the variables associated with epoxy glue time and have read posts here but I am still unsure of how long to leave the panel in the vacuum press. With the cold press glue I know it is important not to leave it in too long but what about epoxy? I also do not really want to leave it in too long and deal with the compressor off and on (it's a venturi press from joe woodworker). I plan to do a few tests first but need a starting point. How 'cured' does the panel need to be before removing?
Also, I usually veneer both sides at the same time on smaller panels. If I do one side at a time on a 1 5/8" door will it present a problem?
