Veneer
Paper backed veneer on maple ply
12/22/18
Craig Member
I'm working on a desk project using 20mil paper backed walnut veneer. This has some cubed type components and my intention was to use this over maple ply using contact cement. After the fact I came across stories of delamination with contact cement and lacquer finish. Others say it's OK to use if you use a veneer hammer or carpet tucking tool to really press in the veneer and then apply light coats of finish. Plan B is to go back to the vac bag where I can with Titebond III and use FSV glue on the the parts I can't vac bag. Now I'm worried about the maple possibly pinking or rippling with the water based FSV glue. Any advice would be appreciated. Also, I use Plum Creek mdf if I can but I prefer the structural properties of ply.
12/22/18       #2: Paper backed veneer on maple ply ...
Paper is not a structural component. You have issues of gluing paper to the substrate, and then the factory glue line between the paper and the veneer. Both are suspect to release depending on your glue choice, your clamping method, and your finish. Personally, I wouldn't consider ever using paper backed. I used phenolic backed one time to skin a door in a church. No complaints from them, but I never saw it again. I also am no fan of contact cement for furniture work. It worked on my kitchen counter, but I don't consider it a veneer glue where edges can get easily damaged.
12/22/18       #3: Paper backed veneer on maple ply ...
duster
Why not use walnut veneered plywood and save yourself the trouble?
12/23/18       #4: Paper backed veneer on maple ply ...
You will have problems with paper backed veneer and contact cement when you get to spraying. That is why poly backed veneer exists. I have not had an issue with paper back when using PVA. You can use the method of gluing both the substrate and the veneer, let dry then iron down pieces that won't work in a vacuum bag.
12/26/18       #5: Paper backed veneer on maple ply ...
Craig Taylor Member
I prefer the PVA glue and will experiment with the iron technique. Has anyone used the FSV glue from Veneer Supplies?
