Veneer
Veneer on softwood
2/27/19
Anthonyg Member
Hello all
I currently have some doors to be done the interior architect want me to use poplar frames and he want me to press on this frames walnut veneer i never did this befor but i think it has downsides i think the veneer will not last
Any one tried this befor
View higher quality, full size image (419 X 500)
2/27/19       #2: Veneer on softwood ...
Snaglpuss
Since you would also have to edgeband the 3/4" edges why not use a decent grade of Walnut plywood for the jambs?
I've done two houses worth of jambs and flat casings for myself out of rift oak ply with 1/8" solid edgebanding. This worked out well, no problems.
I had to custom make the jambs due to plaster walls / non-standard jamb widths and finding enough nice rift solid for the jambs and flat casings would of been difficult and $$$.
2/27/19       #3: Veneer on softwood ...
Anthonyg Member
Thank u for the great tip
He told me that i put the veneer on the jamb and he will stain them all with the same walnut...
I am afraid that in a short time the veneer will crack due to the poplar movement
2/28/19       #4: Veneer on softwood ...
Y.heller Member
It'll be fine with poplar. I would actually use basswood as the core.
edge the basswood with matching hardwood, mill to thickness, cross band the core with .5 or .6mm, then face veneer with 1.5mm. There's your durability and stability.
You can go thinner with the face if you don't want to go to 1.5mm.
2/28/19       #5: Veneer on softwood ...
With all that veneering and banding wouldn't it end up cheaper to use walnut solid?
2/28/19       #6: Veneer on softwood ...
Y. Heller Member
Yeah it would.
I wasn't sure if the architect was specifying engineered for stability or for cost savings. If it's cost savings... You probably just lost it in the labor/time to veneer the parts.
Maybe it would still be under walnut at BF price all said and done with the material and labor costs included. I don't think it would save enough to make it worth it VS just milling solid lumber.
Then again how many doors are we talking? 1 or 100+?
2/28/19       #7: Veneer on softwood ...
It's been a couple decades, but I did the finishing on the trim for a home that was particleboard wrapped with oak plywood. The did a short wrap on the back surface, but it was a single piece of veneer wrapped around all 4 surfaces. There are companies still doing it, why not just sub out the work?
2/28/19       #8: Veneer on softwood ...
Anthonyg Member
Thank u for ur reply maybe i did not make my self clear as the picture all my jambs will be poplar soft wood cut to piece and miled
Sanded and them i put 1 mm veneer directly on the big surfaces of the jamb and stain all together
View higher quality, full size image (720 X 484)
2/28/19       #9: Veneer on softwood ...
Anthonyg Member
Its about 50 doors in a building its a midrange building walnut is very 4 times more costy then poplar
7/30/20       #10: Veneer on softwood ...
Pablo
Personally, I like working with hard woods, I have seen a good article that talks about the characteristics of each of the woods. (it's on his blog)
https://www.dmadera.shop/
