Veneer
Veneer wiggleboard
3/18/19
Martin
I typically stick to solids, but I've got a cabinet requiring custom curved panels. My plan is to laminate a few sheet of bendable ply together over a form, add some solid headers and veneer over. Just wondering if I should add any cross banding prior to applying the veneer, or if I can apply directly over the wiggleboard?
3/18/19       #2: Veneer wiggleboard ...
Absolutely use two ply veneer.
3/19/19       #3: Veneer wiggleboard ...
The poor surface texture will telegraph through a single layer of veneer in some cases. I prefer to crossband.
3/19/19       #4: Veneer wiggleboard ...
You can also use a Dura back or Phenolic back veneer.
3/19/19       #5: Veneer wiggleboard ...
Pete
If you are using thick veneer then I may go one sheet directly to the wiggle wood. If its thin veneer, then yes, I would do 2 layers. Or I may add some Italian bending ply with a smoother face then veneer to that.
