Wood NetWork
Subject: Re: 3/8'' thick, arched rail
7/14/12
Cody  Member
Website: wallbedsbywilding.com
I need to find the best way to make arched rail material that is 3/8'' thick and still has the cope and stick profiles. This will be a mass produced product so the way I have been doing it isn't the best. I've been making 3/4'' thick material and clamping that to my shaper sled and running the cope and stick profile, I need to do this to achieve the needed profiles on all sides, then I have been removing the material through the planner (back side up) until 3/8'' is achieved. this method has a lot of waste and time invested into it. The problem with shaping the material as 3/8'' thick material, is that the sled can't keep the thinner material rigid enough to get a good profile. Any suggestions would be helpful. Thank you for your help.
7/20/12       #2: 3/8'' thick, arched rail ...
B.H. Davis Member
You could build a more sophisticated sled with vacuum holding for the 3/8" part. This should give it the stiffness you need.
    Excel Wood Products
