Wood NetWork
Subject: Re: How to make a 1/8" x 1/8" strip
6/27/13
Asher Anthes
I'm trying to make 1/8" x 1/8" x 30" wood strips, and am having some trouble.
It's too small for the planer and widebelt sander (the material just gets mauled), and tablesaw's aren't precise enough (it usally turns out not square, and then you have saw marks to get off).
Do you guys have any ideas? Or are there companies that just sell the strips?
6/28/13       #3: How to make a 1/8" x 1/8" ...
mark
You can purchase square dowels at the big box stores.
The process for making this would depend on how many, what species, and what degree of finish is required. The last time that I did something similar, was to make some ebony tenon pins. They needed to be square and properly dimensioned, but not sanded. I made these by turning the board on edge and running a couple of saw kerfs into the edge (let's say 3/16" depth to stay with your dimensions). Next I ripped the back side of the board to get a true reference, then flipped it to rip off the dowels. The dowels fall off to the left of the blade. Key to this, or any accurate tablesaw work is the quality of the machine, tooling, and setup. A zero clearance throat plate wouldn't hurt either.
9/4/13       #4: How to make a 1/8" x 1/8" ...
JeffM
Rip them to 3/16 on the table saw and run them through the widebelt. If your widebelt is eating them, something is not right with it.
Diddo with your table saw. Make sure you have a really sharp blade and a zero clearance insert.
9/5/13       #5: How to make a 1/8" x 1/8" ...
David Werkheiser  Member
I know a lot of shops think the table top $400 planers are a joke, but I've had good luck with running small strips. I have a 12.5" 12 year old Delta which uses disposal knives. I use a stationary planer for most of my work, but the "throwaway" can be handy at times.
David
10/17/13       #6: How to make a 1/8" x 1/8" ...
Dave
I ran into the same problem one time. If you can use short lengths you can buy them from a model airplane parts supplier. They will be 18" or 24" long usually and out of Balsa wood or a soft whitewood like Basswood. I think they cut them with lasers.
http://www.usahobby.com/materials/wood.php
    Excel Wood Products
