Wood NetWork
Subject: Re: Drills
Drills
1/1/14
Joe Member
The wood clocks i make I have used mainly regular twist drills for drilling small holes. 0.125 dia etc. And larger holes I use Forstner Drill Bits. And they make lovely almost splinter free holes.
The other day I tried a small wood bit 5/32" Brad Point Bit. and it made a much nicer hole than the regular like metal working twist drill bits.
What bits make the best holes for small sizes like 0.125 to 0.25 inch and in thin wood 0.375 inch and less in thickness
1/1/14       #2: Drills ...
Leo G  Member
Website: http://www.lrgwood.com
You pretty much answered your own question. A steel twist bit is exactly that, meant for metal. A brad point bit is made specifically for wood. It has the two points on the outside that score the OD of the hole before removing any wood. Makes for a very nice entry hole.
1/1/14       #4: Drills ...
Joe Member
Anyone have any suggested makes, brands, etc.? Buy singly online? or have to buy bunches. I only need three sizes,
1/2/14       #5: Drills ...
Bob Anliker
Or, take a twist (metal, 135' split point) bit and grind to a steeper point. You can do this by hand with a bit of practice. First practice sharpening at existing angle. Hold against wheel until sparks come over the cutting edge, then rotate and slightly change angle to give relief behind cutting edge. After a bit of practice with that, change the angle to something steeper. A few twist bits and and a half-hour of practice will have you a new skill. Education is expensive! :-)
1/2/14       #7: Drills ...
JeffD
I would look to Fuller as they make a good quality product right here in the States. Not the cheapest, but since you only need 3 sizes probably worth spending a bit more on a quality product.
good luck,
JeffD
1/17/14       #8: Drills ...
Bruce H
Get a Drill Doctor and sharpen them yourself, keep them sharp. It takes only a minute to grind a bit. We do it every time drilling something important and makes a big difference. Make sure you are running the correct RPM for the size drill bit and the material being drilled.
1/18/14       #9: Drills ...
Joe Member
Speaking of RPM's anyone have a chart of with wood bits what optimal RPM's would be?
On small holes with the twist metal bits I ran pretty fast like for the .125" hole I ran close to 2K RPM.
1/18/14       #10: Drills ...
JeffD
I don't know about optimal, but my drill press shows 8k rpm's for a 1/8" bit in wood. So if you needed you could certainly kick up your speed a bit.
good luck,
JeffD
1/18/14       #11: Drills ...
Bruce H
There are charts for cutting metal by where each has a surface feet per minute value, mild steel is 100, aluminum is 250. You take the SFPM value times 4 and divide by the tool diameter. A half inch bit in steel would run at 800 RPM where an 1/8" bit would run at 3200 RPM. This also calls for a feed speed/chip load which keeps the tool cool. I am guessing that in wood you wouldn't have the feed speed to cool the bit and RPM friction would then play a roll.
    Excel Wood Products
