Wood NetWork
Subject: Re: cherry characterstics
7/23/14
Dan Bechtel Member
In our Cherry wood specifications we call out tolerances for Gum Pockets and Gum Streaks.
My question is, what's the difference between the two.
Gum pockets Maximum 1/4" x 1/4" (6mm x 6mm), must not exceed 4 occurrences per component.
Gum streaks Not to exceed 15% of the surface.
7/24/14       #2: cherry characterstics ...
Gene Wengert-WoodDoc
A gum pocket has a void or space if the gum were removed. A gum streak is merely the stain and does not have a void at the spot in question. So, you can have a gum pocket with a gum streak extending from the gum pocket.
    Excel Wood Products
