Wood NetWork
Subject: Re: Basement gym on wood floating floor
1/29/17
Juan Member
I recently purchased a home with a finished basement. I am planning on converting part of it into a gym area. I am concerned about the durability of the floating wood floor with powerlifting exercises. I plan on taking back the carpet in the gym area and laying down interlocking rubber mats. Is there anything I should do before this to disperse the impact? i.e. laying more plywood etc. Thank you for your time and expertise on the subject!
9/17/17       #2: Basement gym on wood floating floor ...
Nigel J Voller  Member
The problem with floating floors is heavy items will not float the floor will separate and buckle in areas around the equipment.
1/31/19       #3: Basement gym on wood floating floor ...
Serhij Pytlak  Member
Yeah, I would worry about the ply wood scratching up the laminate. Just make sure those 1/2 mats are strong and not the soft spongy puzzle mats.
Would hate for you to drop a plate/dumbbell and jack up the laminate. I laid a floating laminate floor and would NOT want to have to pull up all those pieces and then try to puzzle piece it back together in order to fix a busted piece.
    Excel Wood Products
