Wood NetWork
Subject: Re: Planer slipping out of gear
4/2/17
peter fletcher haigh  Member
I have a Northstate 20" planer ct 508 that will not stay engaged in gear. It was slipping out of the higher feed rate, now will not go into gear at all.
I am not a great mechanic and am just wondering for any helpful tips, suggestions, or input as to how to fix it and if it is even worth it.
I bought it used, got 4 years of use out of it, and have 4 or 5 sets of 20" knives for it, including 2 sets of carbide knives. They are worth more than the machine, but I have a basement shop and fixing this would be a lot easier than replacing it.
Thanks for any help.
4/4/17       #2: Planer slipping out of gear ...
David Werkheiser  Member
Your planer looks to have the same type of gearbox as my 15" Delta, it sounds like one of the gears is worn and that is what is causing it to pop out of gear. I found that when I opened my gearbox that the outer edge of the sliding gear was worn, I also found that the gasket was interfering with the movement of the slide and preventing the gear from fully engaging. After trimming the gasket, the machine has been working for 2 years. I would replace the worn gear but as we all know getting Delta parts has been a real mess
David
4/5/17       #3: Planer slipping out of gear ...
Thanks for the input David. I will give it a try. I was hesitant to open the gearbox but it seems the ultimate destination.
Fletch
    Excel Wood Products
