Strip or remake
5/10/24
Nathan Grabowski Member
Well I have had a major stain issue on a set of 70 drawers and door fronts. They are qsawn white oak. Apparently the stain did not get mixed properly as compared to the face frames and end panels. They are finished with Sherwin Williams water white conversion varnish. Am I going to be money ahead to try and strip these or just remake. Everything is raised panel.
5/10/24       #2: Strip or remake ...
gary
Is it possible to tone them to match?
5/10/24       #3: Strip or remake ...
I had considered that also, but with them being inset doors I thought the toned vs not would show up.
5/10/24       #4: Strip or remake ...
gary
Tone the doors to get them close or the face frames and end panels then tone everything to match?
5/10/24       #5: Strip or remake ...
5/10/24       #6: Strip or remake ...
Pete
Im not following how bc its inset, it would show up? You have nothing to loose by trying to tone them. That would be my first choice before stripping. If you do strip, you most likely will have color issues to deal with bc the same stain will probably not match.
