Subject: Re: Will a Double miter saw do a haunch in one cut.
3/29/14
Brian T
I have a large job coming up in the next month.
We are producing small tables in sets of 3. Each table has two or 3 shelves. .75''x13''x13'' birch ply
The fabrication method I came up with was to haunch all four 90 degree corners 1.5''x1.5'' back from each face. The table legs are 1.5x1.5 solid birch. When assembled the vertical leg and the horizontal shelves are flush.
I then made a jig and doweled the 90 degree angle on the leg and corresponding angle on the shelf. It worked great. It made assembly a breeze.
I did the sample haunches on the slider with a backer to stop blow out. I plan on doing the production run on our pistorious double miter saw which I think will really speed production time up. I know I can do one cut of the haunch by making a positive 45 degree stop coming off of the existing fence and taking off the opposing blade. Is it possible to make both cuts (right and left) at the same time by leaving both blades on?
I think I've seen it done before. Is it done with 2 different size blades or is it just not possible.
I need to produce a minimum of 200 set's so the time savings would be worth a great deal.
Thanks for the help
3/31/14       #2: Will a Double miter saw do a haunch ...
Chris
A double miter saw will do a double miter. The flat part will still be left to cut.
3/31/14       #3: Will a Double miter saw do a haunch ...
Rich  Member
I dont see why not I believe this style saw can be used to do toe notches on cabinet sides. not sure of cut quality on bottom side though.
3/31/14       #4: Will a Double miter saw do a haunch ...
Brian t
Here is what I am trying to accomplish
4/1/14       #5: Will a Double miter saw do a haunch ...
Josh Koschak Member
Setting up a stop and a fence on a good band saw you could whip through those pieces. That, or a dado blade on a table saw.
4/1/14       #6: Will a Double miter saw do a haunch ...
Jarin Smoker
job. The blades are the same size, but one is located higher than the other one so that they cut all the way to the corner. My saw looks a lot like a pistorious double miter saw, except it does not have a long fence but rather a 90 degree fence that you put the plywood side into.
Jarin
View larger image
4/2/14       #7: Will a Double miter saw do a haunch ...
Brian
Thanks for the help.
Jarin,
That was the setup I was thinking of.
It makes sense now.
Having the blades offset like that.
I guess I will be doing 2 cuts per haunch but it will still be clean and fast.
