Subject: Re: Turning Accoya
Turning Accoya
5/9/15
Chad Member
I am turning 3-1/2" x 3-1/2" exterior balusters out of Accoya for an exterior railing I've been contracted to furnish. I'm using a Centauro TC-1200 lathe with the old style horizontal tandem gouges, running one as a roughing and the other as a cleanup. On the first couple trial runs on the balusters I'm running into end grain tear out where the square shoulder meets the beginning of the profile, to the point where I've had to scrap the 3 or 4 I've done so far. I've tried taking 4 and 5 passes, taking as little material off as possible but still having issues. Am I best off to upgrade my lathe to the vertical type gouges that come with new machines or is there another solution I'm overlooking? Any input would be appreciated.
5/10/15       #2: Turning Accoya ...
Read
Chad,
We use a lot of Accoya, though we have not tried to turn balusters.
I'm not surprised that you are experiencing problems. The ascetalization process modifies the original wood rendering very brittle in my experience. I have dropped pieces and they have shattered. I would not like to try bending it either.
The brittleness of the Accoya might account for the difficulty you have at the transition.
5/31/15       #3: Turning Accoya ...
Gene Wengert-WoodDoc
I agree that the treated wood becomes quite brittle and so will not turn well. In addition to chipped and raised grain, heavy stock removal can cause breakage. The best results will happen when using a very slender knife with large rake angles so that the wood is sliced off and not plowed off. Dulling with such a knife configuration is rapid.
