Subject: Re: Glue Injector
Glue Injector
11/25/16
Gary
I am wondering if anyone is using a glue injector ( Like a Pizzi ) to dowel doors and how you like using it. Is it suited for a small shop or just high production ?
Thank you
11/25/16       #2: Glue Injector ...
Pete D Member
I'm a small operation, got one primarily for dominoes/edge gluing and it's awesome. Very fast, easy to adjust glue output and little maintenance.
11/28/16       #3: Glue Injector ...
Fred
Hi Gary,
We use 2 of the Lamello Glue Pots.
For Dowels Larger Surfaces and Edges.
They are an affordable easy to use and clean solution for a small custom Shop.
11/28/16       #4: Glue Injector ...
Gary
I am hoping as I dowel together doors ( 6'8" doors and bigger) they can regulate amount of glue per hole to eliminate tons of squeeze out. Is that a fair expectation ? Lamello makes a small bottle with an adjustable meter on it that I'm going to try for the same goal.
11/28/16       #5: Glue Injector ...
Fred
Hi Gary,
We use 1/2" Dowels for our Man Door's.
Lamello has stock 12 mm Nozzles.
They will make custom 1/2".
We found the 12 mm woks quite well for
what we do.
11/28/16       #6: Glue Injector ...
Alex Sponsor - Rangate
Website: http://rangate.com
Hi Gary,
At Rangate we have quite a few customers who use a Pizzi tank with specialized dowel nozzles (they come from diameters of 6 to 16 mm). I could put you in touch with someone who's using the Pizzi system with dowel nozzles to make doors in your size range if you'd like to hear how they work from someone currently using them. Everything I have heard has been very positive. I've heard of a few people who use a strict metered system where every press dispenses a set volume of glue, but 99% of the time, that's overkill and once the glue gun is in your hands it's easy to get the right amount.
