Subject: Re: Ideal blades for slider & radial
2/25/18
Kyle
I added a Robland Z320 slider & a 16”Delta RAS to my shop last year, and these guys are long overdue for some new tooling...
I make cabs/doors/entry doors/ stairs/yacht joinery& the occasional doghouse/outhouse
Primary species (lately) are European Beech, Jatoba, Sapele & Afrormosia & Iroko from 4/4 -16/4
I’m having a difficult time choosing saw blades, as any search I can come up with, invariably yields beginner type “how to choose your first basic blades” articles/write-ups...
And when it comes to industrial panel saw blades, theres a bewildering variety available, none of which are inexpensive...
On the slider, I need a few different blades.
Firstly , for 2-side veneer core ply (both prefin and not).
I’m leaning towards a Freud HiATB LU3A04 (350mm) or 300mm -06
Then I seem to be using this saw for a lot of my solid stock crosscutting as well, should I be swapping to a dedicated crosscut?
Also also, I find the slider to be a highly efficient straight-line ripper for anything 10.5ft & less, so Im looking for a “standard” 14-16” rip and then a lower tooth “thick stock” type rip for 8/4+ stock
These are all 30mm arbor, so Im hoping a mess of 30mm to 1” adapter bushings will permit sharing the new tooling on my Delta RAS, (still hunting for a high quality NEG. hook 10” or 12” dado set for this)
Any advice or suggestions?
By the way,, there is of course a scoring saw on this slider. But mostly, I just use the main blade, as 1. The scoring motor contacter needs replacement & 2 I cant seem to gain much benefit from using the old split scorer that’s presently on there
Any suggestions for new scoring blade?
2/26/18       #2: Ideal blades for slider & radia ...
Have you tried to speak to Lietz, Lueco or Freud? Speak to the experts, get a rep to come in or get them on the phone.
2/27/18       #3: Ideal blades for slider & radia ...
Forrest
2/27/18       #4: Ideal blades for slider & radia ...
One other thing if you bush a blade for other than it’s normal diameter in my experience you can’t swap it back and forth
3/2/18       #5: Ideal blades for slider & radia ...
John Member
My saws aren't that large, but I've had great performance from blades I've purchased from Carbide Processors. I use their 2 sided Melamine blade and it gives the cleanest cut I've ever gotten on both Melamine and veneer plywood. They make blades for nearly any application, including scoring blades. Not positive, but I think they will make a custom bore blade for you if they don't offer that bore as a stock item.
John
Carbide Processors
3/4/18       #6: Ideal blades for slider & radia ...
We've long used Leuco for all of our saws, never a problem. Last year tried a set of Freud for the Schelling, cheaper but their 200mm trapezoidal scoring blade is pretty flimsy by comparison. Our slider is rarely used with it's scoring blade but the Amana adjustable scoring blade is much easier to adjust then the double blade & shim system. The Omga miter saw has both FS and Leuco blades and both do very well. Bushings are less than an ideal solution.
3/13/18       #7: Ideal blades for slider & radia ...
Bruce H
I use a triple chip grind on my slider. Works for everything. When the teeth are ground down my saw shop replaces them at a little over a dollar per tooth. Been re-building them for twenty years. Buy a blade with a quality blank in the first place.
2/23/22       #8: Ideal blades for slider & radia ...
Mark Henry
