Subject: Re: Automatic sweep on dutch door?
7/8/18
MarkB Member
We have a designer wanting an exterior dutch door. The lower section will have an automatic sweep and we are thinking of running the same in the upper section.
Not a fan of this door option in the proposed location (no protection, fully exposed) and customer wants wood.
Thanks for any input.
7/9/18       #2: Automatic sweep on dutch door? ...
David R Sochar  Member
Not a very elegant solution, but probably the best as long as all involved understand what they are getting.
We do Dutch doors with rabbeted meeting rails, compressible silicone bulbs, and a clear no warranty on the situation. Inswing is what makes them difficult to seal.
7/9/18       #3: Automatic sweep on dutch door? ...
MarkB Member
Thanks David,
We were still planing on the bulb seals, rabbet, and of course no warranty. Due to the exposure I was thinking the automatic sweep on the upper rail would be a little belt and suspenders for minimal extra cost.
I brought all of the issues to their attention several times but they are still heading in that direction. Can always hold out hope.
7/9/18       #4: Automatic sweep on dutch door? ...
I see this playing out as you being directed to use the auto door bottom, then when it is shipped, word will come back to you as "What is this clunky thing?" Then a cost for changing to anything 'better.'
Good luck.
7/9/18       #5: Automatic sweep on dutch door? ...
MarkB Member
May well be the case. We installed a bunch of bottoms in some doors recently (we didnt build the doors they were just in-house for pre-hang and finish) and used bottoms from TM Hardware with the three bladed seals and they seemed like the bee's knees for a weather seal though in the Dutch there is still the pesky edges. We kicked around changing up the rabbeted stop and incorporating some weeps and a very slight outward pitch to the top of the lower door. The standard silicone bulbs at the top of the rabbet as normal as well.
I dont disagree that an exposed are a mistake. May well be a later call saying make another sans Dutch.
8/4/18       #6: Automatic sweep on dutch door? ...
Jay
I didn't see any mention of the species, nor the finish...
the right type/size Pemko retractable sweep could be a good choice for what I am envisioning here.
