Subject: Re: Stave Adhesive Question
11/22/25
Kungur Member
Test
11/22/25       #2: Stave Adhesive Question ...
Kungur Member
I am a retired finish carpenter/woodworker. Have built a number of full size doors both interior & exterior but want to try a stave door.Contacted a company in PA that makes staves and asked what adhesive they use. They responded saying Titebond 3 for both the staves and for the "veneer" to stave.
I recall past discussions regarding this but can't seem to locate.
So looking for advice!
Thanks!
11/25/25       #3: Stave Adhesive Question ...
Monica Chou
Website: https://www.zonledoors.com/
Using Titebond III is the right choice.
Titebond III is the most commonly used and reliable adhesive for interior doors. It has a high waterproof rating, good moisture resistance, and sufficient strength, making it perfectly suitable for stave doors.
11/25/25       #4: Stave Adhesive Question ...
Tom Norton Member
Would Titebond 3 be also the best choice for an exterior door?
11/25/25       #5: Stave Adhesive Question ...
Titebond 3 does lose bond strength at high temperatures. This becomes an issue with exterior doors exposed to direct sun. I do not use it much so I haven't experienced this, however, David Sochar a frequent contributor who is an experienced door maker has.
I would use a type 2 pva for the stave core. I would also use it for the veneer because I have a hot press. You may want to use a non water based glue like epoxy or polyurethane for the veneer to avoid veneer curling while gluing up.
11/25/25       #6: Stave Adhesive Question ...
Tom Norton Member
The door would be a northern exposure.
12/1/25       #7: Stave Adhesive Question ...
Kevin Basto
Im honestly convinced, that people think because Titebond 3 has 3 lines on the bottle it MUST be better.... 3 is more then 2 or even 1 so its gotta be better !!
They should just come out with Titebond 4 already.
