Subject: Re: Door Jamb Material?
Door Jamb Material?
12/25/25
Tom Norton Member
In recent posts I inquired about the fabricating of stave door construction.
Now a question as to what wood you would suggest for the jamb?
Our exterior walls are 11" deep/thick. This is because I have a super insulated home.
Thanks!
12/27/25       #2: Door Jamb Material? ...
Fred Frehner
Hi Tom,
One of the problems we encounter with these thick walls is, for most residential inswing is required. Typically on these net zero homes the insulation is on the exterior. The inside of the wall is uninsulated framing. So your door needs to be in line with the insulated part of the wall. for a single inswing slab this only lets you swing the door to 90 deg, so having doors with a sidelight or a stepped jamb works better.
Often the framing on the exterior of the wall is very limited around the insulation this makes it harder to hang the door.
You will most likely need a deep jamb. Its almost impossible to find standard composite aluminum sill that are that deep, so you will most likely have to build a custom sill. With these net zero homes positioning of the door is very important as the entry is often a weak point due to its positioning in the opening in relation to the insulated part of the wall.
12/27/25       #3: Door Jamb Material? ...
Tom Norton Member
Thanks for your reply.
The exterior walls are 2- 2x4 walls with a 3.5" space between each wall.
Currently I have the existing door frame/jamb set to the exterior wall. The new one will be brought "in" to be set to the interior wall.
Looking for a wood species recommendation.
12/30/25       #4: Door Jamb Material? ...
Wally Robinett
Hard maple or clear vertical grain fir usually makes life easier on deep jambs like that. Both stay stable, take paint or stain well, and don’t feel soft around hinges. I’ve also seen white oak work nicely if moisture swings are a concern. With 11" walls, laminating the jamb stock helps keep everything straight over time.
1/30/26       #5: Door Jamb Material? ...
Seven Member
Website: https://www.zonledoors.com/
Great discussion on deep jamb materials! I’d add that white oak is a standout if your area has big moisture fluctuations—it holds up way better than softer woods. Proper fastening is just as critical as material choice, and these heavy-duty wooden door jamb reinforcement solutions cover the best practices for securing jambs in thick walls.
