Treads/Risers Attach to Skirtboard??
6/3/15
Gary Member
We have construction stringers already attached, with room underneath/between to install finished stairs, left side is closed, right side is open. Builder left 1" on closed side for skirt to slide in against drywall. Do we biscuit the treads/risers to the skirt? One pro said it will squeek, so attach treads/risers to stringer, but what about gaps when treads/risers expand and contract, will there be a gap between skirt and tread/riser on closed side? Thanks.
6/4/15       #2: Treads/Risers Attach to Skirtboard? ...
Steve Member
Website: http://timberline-online.com
Here is one way...
Installing Treads and Risers
6/4/15       #3: Treads/Risers Attach to Skirtboard? ...
Gary Member
Hello Steve. I dont see an answer, just a post to your website. Am I missing the detail?
6/6/15       #4: Treads/Risers Attach to Skirtboard? ...
Steve Member
Gary, click on 'Installing threads and risers' located at the end of my first post.
6/9/15       #5: Treads/Risers Attach to Skirtboard? ...
Skydiver Member
Kreg it or use a Senclamp.
6/15/15       #6: Treads/Risers Attach to Skirtboard? ...
Steeliemark
Not sure I understand, there are temporary stairs in place that you want to build around?
Take them out and install bench built, routed and wedged tread and riser in stringer at the wall, mitered and glued open stringer on the out side with mitered tread returns, just like we've been doing for the last few hundred years
