Bedding glass in water cutoff?
6/17/17
We have a couple small carriage house doors to build that have 6TDL and wood panels below.Over the years weve done exterior projects where we used water cutoff mastic from Carlisle and the stuff is absolutely amazing. Sticky as heck, never gets hard.
Doing the shop drawings on these doors I thought man, that stuff would be great for bedding glass panels in.
We usually run a small kerf on the back of the muntins to leave more sealant right out a the edge and I can imagine this stuff forming basically a permanent o-ring around the perimeter of the opening.
Wondered what the masters thought.
6/18/17       #2: Bedding glass in water cutoff? ...
David R Sochar
RTV silicone is the best sealant I have found. It is compatible with anything the insulated glass maker will use, so your glass warranty is still retained.
