Innovator II raised panel cutter profile depth and reveal
11/22/19
Prangige Member
I am hoping to buy Innovator II cutter heads for my solid wood raised panel making. I own three 7-1/2 HP shapers. I would like to find out the maximum depth and reveal we could achieve for raised panels using an Innovator II cutter head. Please share your experience in using this cutter head to achieve deepest cut and largest reveal. Thank you!
11/23/19       #2: Innovator II raised panel cutter pr ...
Call Charles Schmidt and have a chat with one of their techs. Excellent company.
11/25/19       #3: Innovator II raised panel cutter pr ...
I have two Innovator 3 knife heads with a wide assortment of HSS cutters we have ground for raised panels. We also have used them for copes on special sticking orders. Excellent tooling.
We use a bearing that is about 2-1/4" D on a 1-1/4" D spindle. With knife projections, we have about a 1-7/8" wide panel raise/cutting depth.
You can get a wider cut if you remove the bearing and then it is the spindle and spacers for it that are in the way. Poke the knives out a bit and you could get 2" to 2-3/8" easily. No, I do not know what is safe and what is not on that knife projection. I don't push it, and keep all the head corrugations filled with knife.
