floating tenons
11/28/19
chich Member
making 8/4 Mahogany doors 7'6" high and 34" wide im curious to know if
1/2" russian birch plywood would cause problems used as a loose tenon
11/28/19       #2: floating tenons ...
Use the exact same material.
11/28/19       #3: floating tenons ...
I've always used solid wood. Finding a router bit to match plywood to joinery quality fit has never been something I could coordinate. I guess you can buy some metric bits, but I'm quite a stickler for wood expansion and you don't mention how wide you intend to glue in.
11/28/19       #4: floating tenons ...
chich Member
thank u guys i use a metric bird mouth but and i looked over at some scrap baltic birch left over drom some drawers and walla a perfect fit. u think this ply might swell? all tenons are 6 1/2' in length Width varies for 2-4"
11/29/19       #5: floating tenons ...
Terminology: "Floating" generally refers to the fact that solid wood panels are not glued into a stile and rail assembly. No glue
"Loose" can refer to tenons that are a third part in a mortise and tenon joinery.
I do not think those loose tenons would be any good if they floated.
11/30/19       #6: floating tenons ...
MarkB Member
Im not sure that my concern would be the ply swelling but more the fact of two "not the same" materials and how well they play together. Maybe the ply never swells but the solids do their normal day to day "thing" and poof. Your going to have material (followed by scraps) that are all of the same lot.
More than likely never an issue but with the amount of work your going to put in the doors why bother even risking it when your probably going to have a pile of loose tenon scrap go into the dumpster or the wood stove.
11/30/19       #7: floating tenons ...
chich Member
thanks guys but Mark hit it right on the head he thinks like me (too bad) Its actually called laziness and yes ive used various forms of tenon including ply and it has been fine..Yes so much work in these doors and so many scraps Throw away ply scraps or Mahogany a no brainer Thanks for all your input
