Brandt Optimat KD 56
2/24/19
DimitrieTucaliuc Member
Hello to all
Im new here and I have a small shop in Romania
We have a 2003 Brandt 56 Edgbander with E 1 overpower current error-can anyone hrlps us with this,the machine is block and we dont now where to start
2/25/19       #2: Brandt Optimat KD 56 ...
Paul Miller
Website: http://WWW.MCCWOODWORKING.COM
That is an over current error. (Snapping the breaker.) We have a 2002 Brandt Optimat and we have had similar problems. Usually it is a short in the glue pot. The problems usually are with the glue pot. These get hot, the wires get dried out and brittle and short out. You will probably have to replace the wiring. We have had to scavenge wires off old machines. If you have old equipment, you have to be creative.
It is more difficult to diagnose without seeing some pictures. If you need more help, send me an E mail and I will pass it on to my in house Computer/equipment expert. He can fix anything.
I've heard there are beautiful women in Romania.
2/27/19       #3: Brandt Optimat KD 56 ...
matt krig Member
Look for a breaker in the second panel in the middle of the machine that's tripped. It's the one turned horizontally while the others face vertically. Turn it and reset it.
Most likely as stated above, there is a short in one of the elements or the glue roller drive chain underneath the gluepot has a piece of hard cold glue causing it to bind. this happens when a glue pot overflows, typically from burnt glue interrupting the normal flow.
A heat gun and a stick can usually clean any pieces in the chain and get you operational again, but you'll likely need to disassemble and clean the glue pot sooner than later.
3/9/19       #4: Brandt Optimat KD 56 ...
Harold
Website: http://morantz Cabinets.com
Hey Paul, looking for a mail order? Our president hit one ☝️ Blume and she is a looker. Based off n his present situation , he made gut give you a good deal. 😁
