Subject: Re: Insert Shaper Tooling
2/3/16
Bill Hagers
Good morning everyone. I'm trying to do some research on insert shaper tooling and not turning up great results. As always it's best to ask around. We currently use brazed tooling for all of our C&S door profiles but I'm heavily leaning towards insert for a variety of reasons but only if it is cost effective.
Brazed tooling is expensive and the quality of the joints is a function of how many times they have been resharpened, and the replacement/retipping cost of 6 piece sets gets very expensive if you run a lot of material. Ever since we have switched some of our profiles to insert knives I have wanted to change our C&S over.
My problem is most of the name brands including freeborn are expensive, and you would have to replace the inserts a significant amount of times before it is most cost effective than say a standard freeborn 6 piece kit. The knives I have seen on average are $30+ each, so in many cases it's 6 knives for C&S. I've seen some new heads from infinity but they don't allow glass door profiles which we do a lot of, and I'm not interested in fiddling with a rabbeting cutter and all that fuss, I've been down that road.
Any input would be helpful. Insert tooling has its advantages beyond initial cost, but if it's exponentially more expensive from the gate it's really hard to consider it.
2/3/16       #2: Insert Shaper Tooling ...
dustin orth
I have multiple sets of Byrd tool insert cope and stick sets. As far as cost goes, not sure of much of a comparison. The insert sets are just over 300 per head with the first set of tips. Depending on what you are milling, length of cuts before tip replacement is needed varies, but I'm getting somewhere between 10 and 20 thousand lineal feet of stick cutting before they are dull. I don't know of any brazed cutter that could even come close to that and Freeborne are some that these replaced. Nice thing is the tips are pretty easy to change and no fiddling with shims after a sharpening. Cope knives seem to last forever, think I have replaced 2 sets in maybe 6 years. We also do mostly Knotty Alder with some other woods mixed in. I also have the panel raising cutters and prefer them over brazed tooling as well. Overall I would recommend going insert. Your choice.
2/4/16       #3: Insert Shaper Tooling ...
Dan cook
What about inserts when using composite materials? We sometimes use mdf for the center panel when doing painted doors? How do inserts work for these materials?
2/4/16       #4: Insert Shaper Tooling ...
Chuck Hicks  Member
Bill,
Insert tooling is definitely the way to go. The grade of carbide on the inserts is better because it does not have to be brazed in, this means longer life and better cuts over brazed tooling. The down time is basically none, change the inserts on the cutter and you are back running. Plus, the pattern stays the same unlike when the brazed cutters get sharpened.
Dan, The solid carbide inserts are definitely the way to go on MDF.
Catalog
2/4/16       #5: Insert Shaper Tooling ...
Mike Fuson
I considered going with insert tooling but didn't. I can't speak to the quality of them since I've not used them. I've been using Grizzly's cope and stick industrial cutters and one of their five wing raised panel cutters. $200 for the C&S set and $86 I think for the panel cutter. I get an unbelievably smooth cut. I couldn't possibly tell you how many kitchens I've done with these cutters. At that price and for as long as they last I'm not even going to have them sharpened, I'll just buy new ones. I was using freeborn raised panel cutters before and they didn't cut as well as the Grizzly and was about 4X the money. That's my story and I'm sticking to it. Leave it to me to go against the grain I guess...hehehe
2/7/16       #7: Insert Shaper Tooling ...
Many companies can provide different grades of carbide inserts tailored to the material being cut. For our regular production work we use inserted, for one off jobs we may get brazed and just throw it away when dull.
