Subject: Re: Corner rounder
Corner rounder
2/22/16
Arvin
Just bought used off line corner rounder.the machine seems to go through the operations fine. I think we could use a new correct bit price through Vtap would be $240 which seems high. the current bit seems to be a standard 1/8" round over.i can't seem to get it adjusted right to work perfectly question has any out there used this type of machine? Will the bit from Vtap work better or is it just a expensive 1/8" round over bit . Currently we are using 3mm PVC I had been using a 3mm bit with hand router from Art Betterly that almost worked better but a lot of work for about 800 fronts Help
2/24/16       #2: Corner rounder ...
Bruce H
I don't know about Vtap's bit. My corner rounder uses a Leitz insert bit. It is ground so that it is open a little from 90 degrees. I'd also have a hard time seeing $240.00 for a bit when a 1/8 round over might sell for thirty bucks.
