Subject: Re: What species of wood are you using for painted cabinets?
8/25/16
Brett
Hi,
I'm just wondering what type of wood species you guys typically use for painted cabinets? We have used mostly poplar for as long as I can remember but we have had a couple of problems with the doors warping with the last couple jobs. Some doors that are perfect will end up warping a few months down the road. One of these jobs happens to be inset so you can imagine what a slightly warped door is going to look like. We sub out most of our doors and they have a "paint grade" species that we always use for painted cabinets. This seems to be a mix of mostly poplar with some soft maple mixed in. Would it be the poplar that is warping or maybe a bad batch of lumber? We're possibly thinking of going with all soft maple doors for painted cabinets but would appreciate any of your input.
8/25/16       #2: What species of wood are you using ...
Wyatt
We use soft maple. We have had the same problem with poplar in the past. I told our door company if any doors show up made out of poplar I will refuse them. That stuff just isn't stable.
8/25/16       #3: What species of wood are you using ...
Dennis
I also use soft maple for paint grade doors, aside from the potential for warping, poplar is just too difficult to get a smooth finish on. You can use a "paint grade" maple which has too much color variation for staining but works fine for solid colors.
8/25/16       #4: What species of wood are you using ...
Adam B Member
Brett,
have you ever tried/considered 1 piece MDF doors?
8/25/16       #5: What species of wood are you using ...
JeffD
Soft maple here as well, poplar it just not the best wood for better quality cabinet doors.
good luck
JeffD
8/25/16       #6: What species of wood are you using ...
Leo G
Paint grade is soft maple and I mostly use an MDF panel.
8/25/16       #7: What species of wood are you using ...
Edi Silva  Member
Website: silvawoodworking.com
Soft Maple and Mdf for panels, we primed our panels prior to assemble the doors also.
8/26/16       #8: What species of wood are you using ...
Brett
Adam,
We have considered 1 pc. mdf doors but we have yet to try them. I'm not sure mdf doors would be as durable though. I would be worried about the corners chipping in a heavily used kitchen but maybe I'm wrong. I think we may try soft maple and see if we have a better outcome than poplar.
8/26/16       #9: What species of wood are you using ...
Tony
Definitely soft maple. The grain in poplar will telegraph through the finish no matter how well it's prepped.
8/26/16       #10: What species of wood are you using ...
Dan/drbwoodworks
Soft maple and have used hard maple a few times . We make our doors and can't remember ever having a door warp . We always prime the panels with a tinted primer that matches top coat . If you're spraying lacquer the finish is much better than poplar . I think poplar dents way easier too.
8/27/16       #11: What species of wood are you using ...
Harold morantz
There is an interesting thread in the knowledge forum about the advantages of MDF one piece doors. They are all we use and once finished with a high quality conversion lacquer, they are as good or better than a 5 piece door. We band the square edge shakers with maple or birch banding and our finisher takes it from there.
View higher quality, full size image (2272 X 1704)
View higher quality, full size image (1434 X 1920)
8/28/16       #12: What species of wood are you using ...
The doors look ok in the picture, are the huge spaces above the pull outs there for a reason?
8/29/16       #13: What species of wood are you using ...
Harold morantz
Website: http://morantzcsbinets.com
Our standard is 3mm. The dishwasher looks like it may have been installed a little low and had a larger gap. Expanding a photo on phone or computer always makes these gaps bigger than they are.
8/31/16       #14: What species of wood are you using ...
Soft maple with glued in mdf panels.
Poplar used to grow like a weed. Now with all the extra CO2 it grows as fast as bamboo with some trees having 1 inch growth rings.
It was a poor wood for anything but trim. Now its getting dodgy for even trim. I haven't trusted it for doors for 20yrs.
I think the only thing growing faster than poplar is the poison ivy vines. Isn't climate change great...
9/3/16       #15: What species of wood are you using ...
Soft maple
